603,939 active members*
1,982 visitors online*
IndustryArena Forum > MetalWorking Machines > Bending- and Punching Machines > CNC99 Automec Error Codes FAIL 24, 65
Results 1 to 5 of 5
    Aug 2010
    5
    We recently had a power outage and our Standard Break Press with CNC99 controller is giving error codes FAIL 24 and FAIL 65.
    Can anyone give us information on these codes? Are there any places left that support this system? The autogauge /automec OEM does not support this model any more.
    Any help would be appreciated.
    Regards,
    Jack
    Jul 2021
    Re: CNC99 Automec Error Codes FAIL 24, 65
    Quote Originally Posted by PMFMAN View Post
    Regards,
    Jack
    I see nobody replied to this. I can help out if you still need it. All the "20" fault codes are a stuck key. So, Fault 20 is a stuck '0', Fault 25 is a stuck '5' key etc....
    Fail 65 is the top and bottom stroke switch both active at the same time.
    A month late but hope it helps someone
    Aug 2010
    5
    Thanks for your reply. We sent the Unit off to Radwelll International for Repair. The unit started spitting out Help 28 code as well. Shop would hit different numbers and it would not respond or move the gauge.
    You must have seen this yourself before on your unit? This is the first issue we have had in 30 years on ours. It's been a really good machine.
    Thanks again.
    Jack
    Oct 2024
    How do you fix the Fail 65
    I hear you saying it's the top and bottom stroke switch both active at the same time. How do you fix's it or make it go away
    Oct 2024
  1. Error codes for SCM Record 310 NT Router Error code 075-MACHINE OFF
    By GVANZ in forum Complaints and Praise Discussions
    Last Post: 05-28-2019, 08:30 AM
  2. AUTOMEC CNC 1000 square gage Fail 40 error,,
    By stephanTX_germanic in forum CNC Machine Related Electronics
    Last Post: 03-18-2019, 05:27 PM
  3. error 1050 init.shift fail
    By dango in forum Fadal
    Last Post: 10-17-2015, 03:29 PM
  4. cincinnatti 1250 error 42-11 APC START FAIL
    By rgarciai1965 in forum Cincinnati CNC
    Last Post: 05-18-2015, 06:31 PM
  5. V2XT startup fail error-1
    By photoron2 in forum Bridgeport / Hardinge Mills
    Last Post: 10-05-2006, 05:21 PM
