587,629 active members*
3,545 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > CNCFusion Y-Axis ballscrew too long for Micro Mark
Results 1 to 6 of 6
Hybrid View
    Feb 2004
    1311
    Hi all, I got my CNCFusion kit with ballscrews on all 3 axis yesterday. Everything seems in good condition. Started assembly tonight. It appears that the Y-axis ballscrew is too long by at least 1/4" so I can not tighten the motor mount to the mill base. Has anyone with a Micro Mark had this problem? I suppose the options are;
    1) add a 1/4" spacer between the motor mount and base
    2) hack away the back of the Y-axis slot to make a little more clearance
    3) cut off the end of the ballscrew
    I am not really set-up to do 3. Any recommendations?
    cheers,
    Michael
    Reelsmith, Angling Historian, and Author of "The Reelsmith's Primer"
    www.EclecticAngler.com | www.ReelLinesPress.com
    Sep 2003
    126
    Sounds kinda strange, I am guessing this an X2 type conversion? I like idea #1 . Fast trip to the hardware store for some 1/4" spacers until you can decipher what is goofy should do the trick to get you up and running.
    Jeff
    Feb 2004
    1311
    Yes, the Micro Mark is a Sieg X2. I actually have a 1/4" spacer that I made for my original conversion that used the stock leadscrews. It is ugly as sin though I can use it if needed. I still need to file a little of the Y-axis slot (back by the Z post) to make a little clearance since the screw is just a hair over 1/4" too long.
    cheers,
    Michael
    Use the spacer, you should gain that in extra travel.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Feb 2004
    1311
    I tried the spacer and that would have worked but I would have had to cut out a little from the back of the slot too. Ultimately, I spent 30 minutes with a hacksaw and 1/8" dill bit and removed a 3/8" by 1" chunk of iron at the back of the slot. That gives me the full range of the screw too.
    I got the Y wired up (it was working with my homemade mount and stock screws before the conversion) and gave it a test run. Much faster! Now I know why people recommend ballscrews.
    cheers,
    Michael
    Sep 2003
    126
    Yeah the speed is crazy if all you have had is stock screws, sometimes more then 3X the speed.
    Glad you got it engineered!
    Jeff
  1. Micro-Mark CNC retro and software
    By mkenney in forum Benchtop Machines
    Last Post: 04-22-2009, 05:40 AM
  2. CNCFusion longer X2 Y ballscrew
    By X2cnc in forum Benchtop Machines
    Last Post: 10-29-2008, 01:41 AM
  3. CNCFusion X/Y ballscrew installation
    Last Post: 07-24-2008, 12:05 AM
  4. Micro Mark upgrade problems
    By SPEEDRE in forum Mini Lathe
    Last Post: 02-10-2007, 04:42 PM
  5. Micro Mark
    By xa_shall in forum Mini Lathe
    Last Post: 11-10-2005, 11:24 PM
