588,548 active members*
5,774 visitors online*
Results 1 to 6 of 6
    Aug 2016
    4
    Unhappy CO2 Laser cut SIZE issue.
    Hi All,
    I having issue with my 80 watt Laser X axis. The belt need to be change so I changed it. But issue still same. As I cut 25mm x 25 mm. it cut perfect with tolerance of + - 0.05mm. But when I cut 900mm x 25mm the it cut 907mm instead cutting 900mm. Y axis is perfect. X axis giving issues. Any one can help?
    Nov 2014
    20
    Re: CO2 Laser cut SIZE issue.
    hello.
    what controller do you have and what software do you use?
    maybe you need to recalculate pulse units?
    Aug 2016
    4
    Thanks Marcv. I am using RD Cam V8 and same controller.
    Nov 2014
    20
    I am sorry i am not very familiar wth rdcad but i think there is option under vendor tools where you can adjust pulse cont of x axiss....maybe someone with more experience would jump in
    did you measure 25*25 mm with calliper? i think if you have on 900mm tolerance of 7mm that this around 1% of error and if that it is that on 25mm you would get error too but arround 0.25mm and if you measure with ruller you cannot notice this...
    Feb 2017
    23
    Hello,
    You need change the X axis pulse equivalent.
    Feb 2017
    23
    step 1: click file
    Attachment 350694
    2: vendor settings
    3: read
    4: click-------X axis step lengthAttachment 350696
    5: change like this Attachment 350698
    6k---write
    and then cut-------check-------change X step length
    again and again until size ok.
  1. Fusion 360 text size issue
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 07-21-2016, 06:39 PM
  2. Just installing PathPilot - screen size issue
    By keen in forum Tormach PathPilot™
    Last Post: 08-01-2015, 07:44 AM
  3. Weird window size issue with KMotion CNC
    By spank in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-13-2014, 12:33 AM
  4. Size issue - work too small
    By apuliacnc in forum Controller & Computer Solutions
    Last Post: 02-28-2010, 03:16 PM
  5. Eagle CAM Processor output - Mach3 Size issue
    By deleteallusers in forum G-Code Programing
    Last Post: 05-02-2007, 03:14 PM
