CO2 PSU and TUBE ? Can I use a 40w PSU with a 50w tube ?
I went for the 50w machine, as it seemed a good deal.
It stopped working.
I am noticing 40w spec's are almost identical, but MUCH cheaper !
So, I need to find out if it's the tube or supply that is broken.
Can I buy a 40wPSU and use it with the 50w tube ?
Then if it doesn't work, I will buy a 40w tube.
Also in the future, the 40w will be cheaper each time I need to replace the tube (or supply)
I plan on using the poor little machine, all day every day, once it's working again.
Thanks in advance for any advice ![Smile](images/smilies/smile.png)
Rich
My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html
