587,591 active members*
4,464 visitors online*
Results 1 to 4 of 4
Hybrid View
    Jul 2011
    Angry Colchester 2000L Fanuc OT
    I bought a used Colchester 2000l with fanuc OT
    I cant seem to get the machine from auto(Program,Edit) mode to any manual modes (MDI,jog,handwheel)
    When I put the machine it defaults in to MDI, but when I put it into program mode it will not then go back into MDI.
    Any ideas?
    Thanks, David
    Jan 2009
    22
    Hi David,
    Looks like you cannot select the CNC mode freely. I sorry to tell you the CNC mode is controled by the PMC logic, so the only way to resolve this issue is find out the machine logic. You can find it in the CNC, also sometimes the machine supplier prints it and bind with machine manual.
    Good luck!
    Mark
    May 2013
    128
    Can you jog the axis ? Or any Alarm is there on Screen ? Had you checked the parameters related to MDI ? What I understand Is it , That your MODE SELECT rotary key / Soft Key not working / Functioning ?
    Feb 2009
    6028
    Are you out of emergency stop mode? Estop will make some fanucs stay in edit mode.
  1. Fanuc OT Control/Colchester 2000L Lathe
    By okhan in forum Fanuc
    Last Post: 12-15-2020, 10:06 PM
  2. Colchester 2000L
    By bertcnc in forum Colchester Tornado lathes
    Last Post: 06-25-2020, 07:40 AM
  3. FIRE!!Colchester 2000L Fanuc OT
    By davee1987 in forum Fanuc
    Last Post: 11-23-2012, 01:15 AM
  4. Need Parameters For Colchester 2000L CNC
    By Hakam in forum Colchester Tornado lathes
    Last Post: 10-27-2012, 02:46 PM
  5. Colchester 2000 Fanuc ot cnc
    By SASMAN in forum Colchester Tornado lathes
    Last Post: 01-24-2011, 01:41 PM
