587,737 active members*
3,196 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Colombo RS73 cooling fan question.
Hybrid View
    Hiya,
    I got this Colombo RS73 spindle in 2008 on a small K2 machine. Situation changed and it got put into climate controlled storage until recently. I have everything set up and I can turn the spindle on and off from the machine and I can adjust the rpm of the spindle. What is bothering me is the cooling fan doesn't come on. I don't know if it's supposed to come on with the spindle, or if there is a temperature sensor? I have only run it for a couple minutes until I know for sure. tia
    Re: Colombo RS73 cooling fan question.
    In case anyone else has a similar question, I heard back from Colombo. The fan is powered separately from the spindle. It is a 220vac fan. I need to dig in and see how K2 wired it.
    Feb 2018
    3
    This is an old thread, but still, how did you connect the spindle and fan? This image is from my rs73 and I think three brown lines should connect to the vfd, and two black lines straight to 230V/50Hz. Am I right?
  1. 10hp COLOMBO - FAN COOLING CONVERSION
    By jxdxwx in forum Spindles / VFD
    Last Post: 06-17-2015, 03:28 AM
  2. Quick Question On Cooling Stepper Motors
    By willheg in forum Stepper Motors / Drives
    Last Post: 04-21-2012, 07:50 AM
  3. PDS colombo and Giordano Colombo
    By 15mgtar in forum Want To Buy...Need help!
    Last Post: 07-10-2011, 12:47 AM
  4. Question about cooling
    By matty440 in forum European Club House
    Last Post: 06-17-2008, 09:52 AM
  5. Cooling question
    By cncadmin in forum Computers / Desktops / Networking
    Last Post: 11-18-2003, 02:49 PM
