I read alot of posts about the Feeds and speeds of cutting different materials. Obviously, that varies depending on the machine and your personal setup. I thought it might be a good idea to dig a little deeper and see what feeds and speeds you run for your materials. Also whether your cutting style is fast, small passes or deep slow passes.
Please post a general list of what Depth of cuts, RPMs and IPMs that you cut your materials with and still have good results. Please list your machine as well. Maybe by adding this info, we can give new CNCers a better idea what to expect of the machines.
I will start with my CNC mill which is a SX3 that I CNCed with Gecko's and steppers.
Aluminum (6061-t6) .040-.050 at 3600rpm and 30 IPM (Coolant - HSS and Carbide Bits) (I know I could do more, but this doesn't stress the machine hardly at all.)
A36 plate and bar .010-.015 at 1000rpm and 10-15IPM (No Coolant) 2 Flute (Tailn Coated HSS) ( 3/8" to 3/4" end mills )
1018 plate and bar .010-.020 at 1000rpm and 15-20 IPM (No Coolant) 2 Flute (Tin Coated HSS) ( 1/4" to 5/8" end mills )
(Haven't cut Plastics, Brass or Copper as of yet.)
So, what do you run on different materials? Any of you do deep, slow cuts on steel with coarse or fine roughers in an X3 size mill?
