588,202 active members*
4,535 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Compatible jaws for Tormach 5" CNC vise?
Page 1 of 2 12
Results 1 to 20 of 29
    Aug 2009
    106
    Hello,
    I've got a project coming up that needs soft jaws. I'm also interested in the TalonGrip vise system for aluminum bar machining.
    Tormach's soft jaws are $40/pr, but I see retailers like monster-jaws.com have them down to $12/pr or so.
    Are the 5" sets from monster-jaws compatible? Are there other compatible jaws?
    Has anyone found a retailer selling compatible Talon-Grip jaws? For anyone that has used this system, what's your opinion of it?
    Thanks!
    --Bryan
    Feb 2013
    8
    Good find. I think they will fit the Tormach 5" vice based on the schematic drawing listed here:
    5MJV521A (5x2x1) Standard Extension Machinable Aluminum Soft Jaws for 5" Vises
    I just measured my 5" jaws and the center hole seems to be exactly 3.125" apart and the hole height is within the 0.668 and 0.813 range of the monster-jaw. I'd say order a set because for $12, can't really go wrong. If it doesn't fit exactly, make the hole/slot a little longer with your mill
    Dec 2010
    1230
    I have monster jaws on both of my 5" cnc tormach vises right now. They for like a glove.
    Sep 2010
    166
    I used them on some monsterjaw blanks and made this:
    Machining a mold - YouTube
    Only needs .1" of metal to hold on to.
    Oct 2011
    477
    What was the squealing noise at the end of the video?
    nitewatchman
    Sep 2010
    166
    The brake on the 770 spindle motor stopping the spindle.
    Aug 2009
    106
    mrquacker,
    Thanks, that's exactly what I want to do! Three-side machining, hogging out aluminum, then flip it over and face off the 'bottom plate'.
    I have two vises so one vise can hold the upright part, and the second can have jaws machined as a fixture for holding the upside-down part. Press the button and cut both with one program (I hope).
    I've seen some other fixturing ideas that would increase the density on the table, but I'd like to try it out before buying a dozen of them for fixturing.
    --Bryan
    Sep 2012
    1543
    Monsterjaws work great for the Tormach Vise, I have many... Ask for a discount when you buy 10.
    Jul 2006
    525
    Every shop i've worked in has eventually switched to using monster jaws. You simply cant justify the cost to machine them unless you're a rather large outfit. In many cases, just acquiring the material to make them will put you over the cost of their finished product. Even better, they do a decent job making them.
    As for the talon-grip, they work excellent on smaller parts, and long/narrow parts. Wide parts can make it difficult to take advantage of the tiny carrier they're designed to allow for, but will work fine none the less. I've never had them toss an aluminum part, but while they say they're good to something like rc42, i've seen the jaw portion fail on rc35 material (though I wasn't the one clamping it, and believe they were likely being over tightened.)
    All in all, the jaw system they sell is easily duplicated; I never liked that the ACTUAL talon-grip jaws aren't milled on two sides, etc.. so I make my own jaws. We do buy the clamps from them, though you could make them easy enough as well. Its pretty flexible, and I genuinely love their little stop that locks in. Also nice that they provide solid models, which makes it easy to lay-out material/grip/stop combinations in cad, and allows for set distances between multiple parts, etc.
    Jan 2007
    1332
    I bought 12’ of 2” x 1” 6061 aluminum that I make soft jaws for my 2-piece 3–jaw lathe chucks and for soft jaws for my mill vise. See:
    Tapping 2-56 On Tormach Video by miltons_stuff | Photobucket
    Don
    Apr 2013
    1788
    Could you provide a little more detail regarding how you make imitation TalonGrip jaws?
    Sep 2010
    166
    http://i.imgur.com/sEgR2mr.jpg
    Apr 2013
    1788
    Thanks! Where do you purchase the "talons"? Do most MiteeBite dealers have them (I don't see them at Enco)?
    Sep 2010
    166
    I dont know. I bought mine through Fastenal. 2 per package, Item 32050, 1/2" vise jaw grips. You need 2 packages, so 4 grips.
    Apr 2013
    1788
    Hmmm. According to the Fastenal website "32050" is a 1/4"-14 x 2-1/2" Hex Washer Head TEKS 3 Self Drilling Screw Climaseal Plated! It looks like their part number is SKU 3239577. That tip helps a lot since there is a Fastenal store a few miles from here. Thanks!
    Jul 2006
    525
    Quote Originally Posted by kstrauss View Post
    Mitee-bite provides CAD drawings for basically all of their products online... We buy the grips from Miteebite
  17. #17
    Jan 2007
    869
    I still machine my own. I added a keyway to all my soft jaws as well as to my vise so that the height of the jaws is repeatable every time I install them.
    Saves me time when I have to switch jaws out for a different job.
    Wade
  18. #18
    Dec 2010
    1230
    You added a keyway to the moving jaw? To repeat the height? Do your soft jaws not touch the ways? I use the ways to set the height. It works but over time the aluminum gets scratched to hell from small chips getting under them when installed which decreases accuracy. Interested in seeing how you made the keyway
  19. #19
    Jan 2007
    869
    I learned about doing this from my friend who taught me how to do machining. He has been using it for years. It works great. I use a 1/8" woodruff cutter to make a slot in the vise itself that is exactly in the middle of the bolt holes. I go about .07" deep, a litter over 1/16".
    Then, when I machine my soft jaws, I use a 1/8" carbide endmill to cut a groove .07" deep thru the bolt hole area. After I mount the newly cut soft-jaws, I can cut whatever clamping system into them that I want, and shave them off to a set height.
    I do not touch the soft jaws to the ways of the vise. When I machined the moving jaw, I just put a long, narrow parallel between the jaws so that jaw was opened the exact distance and there was no twist when it was tightened.
    I typically only machine aluminum, so it's not going to goof up the ways if stuff get's under the jaws.
    It was interesting actually, my neighbor who used to be a machinist was over last night, and he was watching how I setup my vises, and asked me where the heck I learned that, because when he was on the job, the stuff I do for my work holding would have saved him a ton of setup time.
    Wade
  20. #20
    Jul 2006
    525
    Quote Originally Posted by wwendorf View Post
    Wade
    Its common practice though to install a keyway or pin that locates the jaw side to side; the vise itself already takes care of the other two directions.. so I can't see a purpose in causing the jaws to float. Quite frankly, you're not going to achieve higher accuracy than the bed of the vise itself, which is traditionally surface ground parallel to the base of the vise.
Page 1 of 2 12
  1. Tormach or GMT 6" vise
    By stumpmonkey in forum Tormach Personal CNC Mill
    Last Post: 11-19-2012, 04:24 PM
  2. VISE JAWS
    By vegas705 in forum Polls
    Last Post: 11-17-2009, 03:46 PM
  3. Soft jaws for the Tormach vise?
    By zephyr9900 in forum Tormach Personal CNC Mill
    Last Post: 10-29-2007, 06:13 PM
