587,149 active members*
5,353 visitors online*
    Sep 2009
    40
    Compensate for skew axis
    I have a homebuilt CNC with an Ozito as the spindle. The controller is an Ebay purchase and runs like a charm.
    The problem I am experiencing is the X and Y are not square. Try what I may I cannot get it quite right. I looked through the EMC documentation but did not see (or perhaps understand) any way to compensate for the misalignment. I found the backlash compensate code and was hoping others could point me in the right direction.
    Cheers,
    Andrew
    Nov 2005
    496
    on the EMC wiki is this:
    EMC Documentation Wiki: ContributedComponents
    it replace the trivial kinematics module with one that allows skew corrections.
    I have not used it nor know how. Hopefully it is easily figured out.
    Chris M
  1. Compensate Z flatness
    By rdpdo in forum Mach Software (ArtSoft software)
    Last Post: 03-28-2010, 07:30 PM
  2. Replies: 2
    Last Post: 02-16-2010, 07:57 PM
  3. Use knee to compensate for tool length changes
    By Korellibopper in forum Mach Mill
    Last Post: 12-07-2009, 05:29 AM
  4. Press bed skew
    By dminnich in forum Diemaking / Diecutting
    Last Post: 07-07-2009, 11:46 AM
  5. Press bed skew
    By dminnich in forum Uncategorised MetalWorking Machines
    Last Post: 07-01-2009, 05:38 PM
