I've noticed on fine detail work, the table on my fixed gantry mill is slightly uneven. For most parts this isn't a problem, but one thing I'd like to use it for is PCB etching, and so the vertical tolerances need to be pretty tight. Since I can fairly easily measure the amount I need to displace the Z position just by jogging and touching around, is there any way in Mach3 to compensate for this? I was going to make a script which automatically transforms the coordinates in the gcode, but I'm hoping for a more general solution.
