603,979 active members*
1,457 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > -->Completed setup minimill-- X,Y ok.. BUT Z-AXIS has problem--- Need advice!!!
    Oct 2006
    142
    Hello guys,
    I am using hobbycnc 200oz-in 3 axis drives/motor and I completed mounting 3axis with the mini mill show in the picture. I am running the software with MACH3 and motion seems fine on X-Y axis.
    One problem!!! The z-axis when move down seems ok, but when it move up SOMETIMES it lag few steps before it pulling the spindle head pull up.
    I believe the reason might have to do with
    1. Motor 200oz-in is not powerful enough to pull up the spindle head?
    2. Too much friction between coupling at the contact with the motor mount.
    This is the first machine I built, so I assume that Mach3 and Driver should be ok and the problem lies mainly on MECHANIC!!!!!
    Any advice from experience people?
    Thank you
    Jeff
    Attached Thumbnails Attached Thumbnails miniharborfreight.jpg   z_axisproblem.jpg   z_axiszoom.jpg
    Jul 2005
    442
    The stock screw has a LOT of backlash.
    Change out for an acme screw - you may be able to use the X-axis lead screw (available from Little Machine Shop)
    Counter weight the head to offset weight.
    Aaron
    Jan 2004
    45
    Thats characteristic of backlash, happens both ways but always more noticable on the way up. Will badly affect your accuracy in CNC environment.
