603,785 active members*
19,320 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > Completely new to this -_-" ... So I decided to start by building of my i3 pro b ????
Hybrid View
    Aug 2024
    Sooo I have a question in regards to grbl and ugs... Firstly sorry if I'm in the wrong place I'm sure this same if not similar issue has been answered till the cows come home... But I'll try to make this easy... Basically I've converted my old i3 printer to run my Dremel.. seemed to do what I need for the moment until I can get a grasp of what I'm doing.. it's running nema 17 steppers x gantry is just belt and rollers with the Dremel adapter, y axis is belt on linear bearings and z axis is dual motor threaded rod, I have - x,y,z limit switches with + x,y,z on the same switch in parallel on nc. That's basically the gist of the physical build.... I found the Dremel adapter on thingiverse " i shall quote them when i find the listing for anyone wondering and credits to them..
    So I'm able to home it I'm able to zero it if I run a Lazer cut through ugs without a laser I'm able to run the nc open the g code export outline and run a job . However dependant on my hard limit soft limit settings it will either ignore the hard limits or go past my soft limits...I even dropped the max from zero 0,0 and max 50.00mm on $130,$131,$132 if I disable the limit switches I can get it to run uninterrupted.. however it will ram the + end of the axis on all axis except z.. which is good i guess damage wise.so things are kinda doing what they should from what i can tell... My issue besides the limit switches being confusing to setup.. is why is it ignoring my maximum limits? I have since starting to type this found that my ugs logo I put in design is 25mm x 25mm.. but when outlined and run on the visualiser it is showing 400mm x 400mm x 5mm.. I tried external pocket mill aswell from camplete tool path in fusion.. same issue they're both set to metric but no matter whether its drawn in ugs or externally.. for whatever reason my drawings are blown way out of scale and i think that might be alot of my issue..Any help would be super appreciated.. get it going I'll even plate you a thankyou placard ???????? thanks everyone regardless just happy to be able to reach out !!
    Mar 2015
    462
    Re: Completely new to this -_-" ... So I decided to start by building of my i3 pro b
    Just a few remarks,
    You have to setup UGS using the correct controller/firmware.
    3D printer software is not realy suitable for a CNC router.
    Depending about the firmware, but after homing, your positions are set to zero.
    Soft limits require the machine to be homed.
    Check the working of the limit switches after homing without zeroing the positions
    Check the working of the soft limits after homing without zeroing the positions and use the jog keys to move the machine.
    Check the gcode to see if the size in gcode matches the expected size. If you make a new gcode file in UGS, it will add code to mill a 10 mm rectangle. Check the size of the square in gcode to the size in UGS
  1. Decided to get XR3 pro. Any advice?
    By steedspeed in forum OneCNC
    Last Post: 11-14-2009, 06:51 AM
  2. OK... I'm going to start building !
    By cdsgraphic in forum CNC Wood Router Project Log
    Last Post: 12-29-2006, 06:54 PM
  3. Questions on building small (18" x 24" x 3") machine
    By bikedude880 in forum DIY CNC Router Table Machines
    Last Post: 08-01-2006, 03:04 AM
