588,624 active members*
5,306 visitors online*
Results 1 to 8 of 8
    May 2007
    1026
    Compressor choice for ATC
    I'm looking at adding the ATC/PDB to my 1100 and as part of that I am looking at upgrading my compressor. I have one of the small California Air Tools units (the 4610 model) that I use right now just for a fogbuster, and I suspect it might not be enough. The Fogbuster uses a decent amount of air and from what I've read a lot of people like to run their PDBs at ~120PSI which is the cutout pressure on the compressor. I do like how quiet the CAT compressors are and am considering one of the slightly larger models.
    This one uses 2HP pump and larger tank so it has >2x CFM over mine. Kickoff pressure of 125PSI.
    https://www.ultraquietaircompressor....CAT-10020C.htm
    This one is a higher-pressure (and lower CFM?) model and has an automatic drain which is nice. A little more expensive:
    https://www.ultraquietaircompressor....-20015HPAD.htm
    Just curious if anyone else has either of these or another QUIET compressor they'd recommend. Not looking for anything crazy like a screw or scroll compressor as I don't use air for anything except the Fogbuster and cleaning off parts.
    Jun 2014
    1774
    Re: Compressor choice for ATC
    5 HP Puma 60 gal 2 stage set at 155 # , covers all my needs just fine except one.................100db when it runs ha!
    mike sr
    Sep 2009
    624
    Quote Originally Posted by popspipes View Post
    Same with my 2 cyl 5 hp old iron. Upside is, I can't hear the chatter from the mill....
    Mar 2009
    1863
    3.5 horsepower Kaeser screw compressor. So quiet you can stand next to it and talk on the phone.
    Only problem? $4,000.00
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Nov 2007
    2151
    I went with a Porter Cable 155 psi 2 stage upright model "Made in America ". They recently opened a new hardware store near me and had them on sale for $355.00 assembled with regulator and quick coupler. Best price I had found before that was 550.00+. PDB works much better and cycles at 120 psi. I also have a host of other air tools so this was a great addition to my shop.
    Oct 2010
    670
    I use this one for my mill running PDB, FogBuster and air gun use. I adjusted when the air recovery kicks in. It has served me well.
    https://www.homedepot.com/p/Californ...020C/206644539
    Looking to get one of these as money allows.
    https://www.eastwood.com/eastwood-qs...ompressor.html
    The Body Armor Dude - Andrew
    Nov 2012
    591
    Tormach sells a California Air Tools for use with their power draw bar and automatic tool changer.
    It's nice and quiet (a scroll compressor) and sufficient for the needs of those accessories.
    You'd want at a minimum to pressure/flow reduce if you also use this for frequent air blast. because it's not super big, so full flow/pressure would deplete it.
    On the other hand, if you really need something bigger, go for a shop air system with secondary storage tank and chiller dryer stage. Then you can use it for grinders, sand blasting, and all the other shop air needs.
    May 2007
    1026
    The compressor tormach sells is the one I have now. I’m almost sure it’s not a scroll compressor, just a slower-running piston design that is a lot less noisy. Nothing wrong with it except that it runs about half the time I’m using the fogbuster which is most of the time. So I wanted something with a little more capacity to allow me to run the PDB on the tight side as seems to be preferred by many.
    Smokediver’s second link is a true scroll compressor, a steal at only $1500. I don’t need 12cfm at 90psi but if I did I’d give that a look.
  1. PDB/ATC compressor
    By Dark Side in forum Tormach Personal CNC Mill
    Last Post: 12-24-2011, 09:53 AM
  2. Air Compressor
    By MatthewBasaraba in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 11-15-2011, 05:00 AM
  3. Air compressor
    By Toolz_86 in forum MetalWork Discussion
    Last Post: 11-13-2011, 01:29 PM
  4. compressor help
    By advt001 in forum MetalWork Discussion
    Last Post: 04-07-2010, 04:04 PM
  5. Compressor
    By Crazycorkey in forum Hobby Discussion
    Last Post: 01-30-2007, 10:02 AM
