I have an older computer and I downloaded K CAM to run the demo,but when I got to the point for the system timing test it fails.It always says actual feed rate zero.I tried it on my new computer and it works fine.
So what do you think the minimum requirements on RAM and procesor speed should be.If anyone is running this software with any luck I would like your input.I do not want to spend a bunch of money on a computer that will only be in the garage to run my cnc.What I have now is a 75 megahertz procesor with 32meg of ram.
THANK YOU
