603,344 active members*
3,678 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > Concept Turn 155 C Axis Error
    Jan 2006
    182
    I just got a concept turn 155 theat needs some love, but I'm having g pretty good success. I do have a problem with the C axis. Activating the axis completes with M52, but any motion I command or even G28 with the C axis throws up the attached error.
    Has anyone seen this before?
    Sent from my SM-G998U1 using Tapatalk
    Jan 2006
    182
    Re: Concept Turn 155 C Axis Error
    I somewhat answered my own question. It turns out that while MDI will allow you to execute the M52 to activate the c axis, if you try to do any other movement from the MDI (G28 C0, G0 C###, etc.), it throws this error. As part of a program, the exact same commands work fine.
  1. Concept Turn 155 Turret Make / Model (Live Tooling)
    By tcom-frazzled in forum EMCO Lathe
    Last Post: 06-03-2024, 07:26 PM
  2. EMCO PC Turn 155 9023 Error
    By mp25 in forum EMCO Lathe
    Last Post: 10-02-2023, 07:34 PM
  3. Emco Concept Turn 155 ACC
    By Fire_in_the_hole in forum EMCO Lathe
    Last Post: 09-12-2022, 02:13 PM
  4. Presentation and help about Emco Concept Mill 155
    By INNMILL in forum EMCO Mills
    Last Post: 12-05-2017, 08:37 PM
  5. Replies: 0
    Last Post: 03-17-2016, 09:21 PM
