Hey, i've recently discovered my school is in possession of one of these lathes. They appear to be rather good and I am starting to get to grips with the software interface but I am still having major issues trying to actually understand the workflow.
Say I have a DXF of a part I exported from Solidworks, how would I generate a toolpath from this DXF? The software seems really poor to be honest.
I am also having an issue with the tool changer. It's stuck on tool 0 when I enter NC mode in WinNC and when I try to manually change it to anything else using the software the machine makes a sound as if it's going to start moving but then doesn't actually do anything and just gives me a tool change timeout error.
So to sum up, how would I fix the tool change timeout error and how exactly do you generate toolpaths?
Extra information: I'm using the CAMConcept (WinNC) software that came with the machine and the machine itself is a late 2007 model that has seen no use whatsoever apparently and is connected to the PC via Ethernet.
