587,083 active members*
2,833 visitors online*
Thread: Concrete VMC
Page 15 of 16 513141516
Results 281 to 300 of 305
  1. #281
    Dec 2008
    33
    Re: Concrete VMC
    Quote Originally Posted by stef110 View Post
    Hey David,
    I selected the rails on a feeling. its not really based on a calculation. i bought them all on aliexpress at the same seller:
    https://nl.aliexpress.com/store/4373...ead_12242861.0
    Stef
    Thanks Stef, I was wondering if you had designed them around your intended use ( or safety factor ). Keep up the posts, really enjoy them!
  2. #282
    May 2016
    108
    Re: Concrete VMC
    Yesterday i decided to upload my 3d model of the VMC to Grabcad, So maybe one day someone can get some inspiration from my build.
    It can be downloaded on https://grabcad.com/library/epoxy-gr...cal-cnc-mill-1
    Also made some new progress on the engine block build:
    Stef
  3. #283
    May 2011
    790
    Re: Concrete VMC
    Fantastic workmanship as always!
  4. #284
    Mar 2004
    1306
    Re: Concrete VMC
    Nice. Why the billet crankcase for the Zundap? Original no longer available, or some serious modding?
    Mark
    Regards,
    Mark
  5. #285
    Jul 2020
    Re: Concrete VMC
    Stef, you create amazing things.
    This thread contains a lot of value, especially when you read it from the beginning and understand how you went through all this.
    What is your next project? In one of the posts, you've mentioned a trunnion table.
  6. #286
    May 2016
    108
    Re: Concrete VMC
    @ rotarySMP tnx, yes its because they don't make it anymore. But mostly just because it can XD For now there are no serious mods on the model. My main idea was to make it a Hybride engine. Patrol and electric combined.
    @ edviukas Also thanks, Next project well is should definitely finish the enclosure... and make a floodcoolant work. Im currently looking more in to a 4th axis then a full 5 axis trunnion to be honest.
    Btw i have made a part2 of the machining of the eninge:
    https://www.youtube.com/watch?v=vaTxCMCRH9A&
    Stef
  7. #287
    May 2008
    1185
    Re: Concrete VMC
    That might be the nicest machine work I have seen here.
    Great video.
    youtube videos of the G0704 under the name arizonavideo99
  8. #288
    Aug 2006
    285
    Re: Concrete VMC
    @stef110 I've been working on a similar project for quite a while now. If you could do it all over again, is there anything you would change? Are there anything you are particular happy about? Any surprises? I'm trying to see if there is anything i've missed or should reconsider before i move from CAD to the real world...
    Awesome work you have done! I (and my wife!) partly blame you for my project ;-)
    /Thomas
  9. #289
    Jul 2017
    26
    Re: Concrete VMC
    This evening we flipt this 350kg beast. And pulled off rest of the mold. Amazing how it all turned out i never expected to be this smooth.
    Next thing to do is the frame, then lift this beast on the frame and then do a post cure with a heater underneath it.
    @ AutomatedIngen
    All those side screws are there for mounting the enclosure there are probably more bolts in there then necessary but who cares.
    I get your idea about the head made from 2 pieces but i like to make mine out off one single piece i think.
    I would like to see your head design to get some inspiration
    For the vibration i just hired a concrete vibrating needle and putted it in the EG.
    steff110 can you share more details about the thread inserts?
    Which parts did you used? I realized that besides the nut, washer and screw there are other parts
  10. #290
    Mar 2017
    411
    Re: Concrete VMC
    The entire model is on Grabcad including the hardware. See post 283 https://www.cnczone.com/forums/verti...ml#post2400032
  11. #291
    Jul 2017
    26
    Re: Concrete VMC
    Quote Originally Posted by maxspongebob View Post
    Thanks maxspongebob! I saw and opened the 3D project , but the insert/plug is just one body, and I didn't understood very well.
    Maybe you can help me with that.
    He used this nut (example link below) with a screw and washer, right?
    https://www.amazon.com/Coupling-Stra.../dp/B07Q2SYQWB
    But what is it at the end of the nut? and how was that part fixed to the nut? this is my question
  12. #292
    Mar 2017
    411
    Re: Concrete VMC
    I think that is a short piece of tube so that the embedded nut with the threads is buried deeper into the EG. The long nut is held in the casting by the washer and bolt.
  13. #293
    Jul 2017
    26
    Re: Concrete VMC
    Maybe...
    I've looked at these images about 100 times lol
    sometimes it looks like he machined the tip of the long nuts, maybe to make it less apparent on the granite epoxy surface
    look where I made the red circle in the image, the long nut length is less than the standard size
    Attached Thumbnails Attached Thumbnails 2019-04-14 13.37.25.jpg   2019-04-29 19.50.33.jpg
  14. #294
    Apr 2008
    127
    Re: Concrete VMC
    It looks like machined end of long thread nut
  15. #295
    May 2016
    108
    Re: Concrete VMC
    Yes i turned down the end with the lathe. Only to just make it look more nice on the casting. It has no other value then that.
    In the model i made all these small nuts bolts and washers to one solid part to make the model easier.
    Stef
  16. #296
    May 2016
    108
    Re: Concrete VMC
    I decided to build a 5th axis trunnion for the mill. Something i already wanted to build for a long time. I decided to make a video serie about it on youtube here is part 1 with a explanation and the making of the first part.
    Stef
    https://youtu.be/iDlHIduj06c
  17. #297
    Dec 2016
    134
    Re: Concrete VMC
    Great work. Looking forward to see it on the mill.
  18. #298
    May 2016
    108
    Re: Concrete VMC
  19. #299
    Nov 2020
    361
    Re: Concrete VMC
    Beautiful work Stef. The technique you used to align the column, where you use bolts and threaded inserts interchangeably, does it have a name? Where did you read about it?
  20. #300
    Apr 2021
    Re: Concrete VMC
    i need parameter takisawa tw 30 fanuc 21TB
  1. Using concrete as a fixture
    By GITRDUN in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-30-2015, 09:17 PM
  2. Concrete Stamp....
    By AussieGecko in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2013, 01:25 PM
  3. Replies: 0
    Last Post: 11-28-2012, 06:39 PM
  4. Concrete Lathe
    By tusavision in forum Linear and Rotary Motion
    Last Post: 01-18-2010, 01:26 AM
  5. Polymer Concrete
    By ericdwilso in forum Vertical Mill, Lathe Project Log
    Last Post: 11-13-2006, 06:22 PM
