603,935 active members*
2,996 visitors online*
    Jan 2006
    8
    configure run button
    hello everybody
    Can we configure a parallel port input pin to run button?
    thank you!
    Mar 2003
    35494
    Yes. You set up the input as an OEM trigger with the appropriate code. YOU CAN FInd the info in the manual or the customization Wiki at www.machsupport.com
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
