587,101 active members*
4,751 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Confused with probe wiring / Mach3 setup G540
Results 1 to 6 of 6
    Jul 2013
    84
    Exclamation Confused with probe wiring / Mach3 setup G540
    Hi Forum,
    I have successfully wired my home and limit switches to my G540 running Mach3 under windows... All good and happy here. However I have setup a probe and cannot seem to get it working, here is the scenario
    Enabled Probe in Mach 3 - Active low
    Probe connected to G540 via 4 and 12 (common)
    Check continuity with multimeter for wiring up to the G540 board - works as expected in a NO configuration.
    on Auto-set under mach 3 could not get the damn thing to work
    Checked in diagnostics no inputs light up when probe is connected
    So I opened the G540 box, set mach3 to auto set for probe on active low, then use a straight wire between G540 connecter 4 and connector 12 to simulate a probe eliminating any wiring issue outside the box. - Still no joy ........WTF
    any guides here?
    Jun 2014
    777
    Re: Confused with probe wiring / Mach3 setup G540
    this could be a silly question but easily overlooked. is it set to the Correct port? a simple test to see if the function works would be swap probe pin setting to a working limit switch and trigger it.
    Jul 2013
    84
    Quote Originally Posted by Jon.N.CNC View Post
    I have been looking - what port /pin is the correct - for limit switches the autoset worked fine, they are 10,11,12 pins, So probe will be 9 or 13 at a guess?
    Mar 2003
    35538
    You can't use pin 9.
    Input 4 on the G540 is pin 13.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jul 2013
    84
    Checked on the G540 manual, connector 4 on the board is pin 13, so i have set this
    it is set active low (NO) do i need to place a resistor or similar?
    Jul 2013
    84
    Ok solved it, thanks for all the replies,
    May bad- the connector was intermittent faulty at the end of the probe, so i replaced and working fine, was going crazy there for a while
  1. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  2. Gecko G540 mach3 setup motors not turning
    By Samvoodoo in forum Gecko Drives
    Last Post: 05-29-2013, 02:23 AM
  3. 4th axis setup G540 and Mach3
    By HakBot in forum Gecko Drives
    Last Post: 10-19-2011, 01:16 AM
  4. G540 and Mach3 setup for dummies...
    By forrest39 in forum Benchtop Machines
    Last Post: 01-14-2010, 06:47 AM
  5. Mach3/Gecko G540 setup questions
    By mlabruyere in forum Gecko Drives
    Last Post: 12-14-2009, 11:05 AM
