603,947 active members*
2,556 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Connecting encoder with kflop and snapamp with closed loop mode
Results 1 to 5 of 5
    Mar 2010
    20
    hi
    I'm planning tout setup brushed motor with kflop ans snapamp and use them un closed loop.
    I was wondering if I need tout connect the motor's encoders to thé kflop board AND the snapamp board too or just to the snapamp board ?
    I think encoders must ne connected to the two boards because one will setup the closed loop and thé other will synchonize thé step/dit pulses ...
    I have not see any example of this configuration un help section
    Thanks you for help !
    Jun 2013
    1041
    Re: Connecting encoder with kflop and snapamp with closed loop mode
    You will only need to wire your encoders to snapamp. With snapamp there is no step/dir needed. It is pwm. Just hook up the encoders and motors power. You will need to run a short c program to initialize snapamp. The info to do this is in the snapamp section of the help files. Then configure your axis in the configuration and flash screen in kmotion.exe. Then tune your motors and set your velocity acceleration and jerk parameters in the step response screen.
    Ben
    Mar 2010
    20
    Ok but if I want to close loop with kflop board i need to connect encoders to kflop too no ???
    May 2006
    4091
    Hi rdpdo,
    No. KFLOP can read data from SnapAmp through the 16pin ribbon connection including encoder positions, bridge driver currents, supply voltage, I/O, temperatures, etc.
    HTH
    Regards
    TK
    http://dynomotion.com
    Mar 2010
    20
    Ok ! Thanks you very much
  1. Setting up KFlop + KStep closed loop stepper system
    By eerohaahti in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-16-2015, 01:45 AM
  2. Position Mode Drive - To pass encoder signals on to KFlop or not?
    By DeanW in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-01-2013, 03:17 PM
  3. Replies: 0
    Last Post: 03-13-2012, 11:15 PM
  4. MACH3 closed loop encoder interface
    By RomaxxCNC in forum News Announcements
    Last Post: 05-28-2010, 11:59 PM
  5. Mach EMC Maximum Encoder Count Closed Loop Servo EMC/MACH3
    By bad bearings in forum Open Source Controller Boards
    Last Post: 05-28-2009, 05:44 PM
