Hello All,
I've got a Dyna 2400 mill with electronics that still works... Just.
I'm trying to connect a FlashCut Signal Generator to the stepper drivers of the Dyna. Not vey well so far.
Has anyone done this before?
I need the pinout for the FlashCut SG. Also the Pin-In (?) for the stepper drivers on the Dyna.
The Drivers connect with a 6 lead plug. Do you have any idea how this should wire?
One more, if I may... I need the signal requirement for the Dyna drivers. Things like leading or trailing, low or high, etc...
Thanks for any help you can give.
Erez.
