Hi all,
I was just wondering if it is possible to wire two power supplies together in such a way to increase the voltage. Kind of like wiring two batteries, or does it not work this way for power supplies? I have two 12 volt power supplies, one is 4 amps and the other is 10 amps, I want to join them so that they make a 24 Volt supply, would I also add the amperage? And how would you wire this?
Thank you very much for the help.
I really appreciate it.
