588,191 active members*
5,149 visitors online*
Results 1 to 4 of 4
    Apr 2007
    6
    constant surface speed
    I am primarily a plastics machinist and I was wondering about running some stainless 304. I want to use constant surface speed so that I can get a good chip break. On a haas sl-20 will this work for constant surface speed of 650 sfm?
    G54
    T101
    G97 S500 M03
    G99 G00 X3.1 Z.1
    G96 S650
    G50 S2595
    G00 Z.01
    G01 Z0. F.01
    Z-.25
    G00 U.01 Z4.
    I'm thinking I need the g97 to get the spindle turning, then I have the
    g96 s650 for the constant surface speed, and then the g50 s2595 so that the machine does not exceed the maximum of what my chuck is rated.
    Oct 2003
    263
    I think it would be safer to put the G50 line before the G96 line. Once you call G96, it could be too late to benefit from the G50.
    Also, if you're only turning a single diameter, there's no benefit from using G96.
    Software For Metalworking
    http://closetolerancesoftware.com
    Jul 2007
    60
    Mike is correct...
    G50 before calling G96.
    you dont need a G97, altho i know some people program a standard G97 S100 M3( or M4 ) at rhe start of the tool and do not invoke G96 until tool is at the work piece.
    I m/c S304 at 160 ( metric ) Surface Meters per Min. - turning/boring - slightly slower if using 0.4r tips and need really good finish.
    ST
    May 2006
    214
    I will do it like this, assuming you did the homework with the RPM.
    T0101
    G50S2595M3
    G96S650M8
    G99G0X3.1Z.1
    Z.1
    G1Z0.F.01
    Z-.25
    G0U.1Z4.
    G97 Will keep the RPM steady good for drilling operation only.
  1. Constant Surface Speed
    By raymond1 in forum Bridgeport / Hardinge Mills
    Last Post: 07-25-2015, 07:41 PM
  2. Is "Constant Speed" important?
    By Hamadamj in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-11-2007, 11:53 PM
  3. Replies: 11
    Last Post: 03-11-2007, 10:35 AM
  4. Is "Constant Speed" faster?
    Last Post: 02-12-2007, 08:45 AM
  5. surface speed and feed rate calculator
    By derkiow in forum MetalWork Discussion
    Last Post: 06-05-2006, 01:33 AM
