Hi there,
The CN tower project is nearing completion. The mechanical part is almost finished, I'm starting to work on the electrical cabinet and some functions.
If some of you are interested, I could post pictures.
I come back to this post because I would like to integrate an analog joystick (see attached photos) for moving the X and Z axes.
It has 4 5K potentiometers corresponding to each direction. It can therefore control movement on 2 axes at different speeds.
Do you think MK3 and TNg can handle this kind of hardware with the Jog connector? And if so, what settings and connections should be considered?
I ask myself this kind of question because on the Jog connector, we find only one pin for the potentiometer.
best regards
