603,848 active members*
2,658 visitors online*
    Mar 2004
    500
    Contour probe digitizing
    I was wondering if there is a cheap software to convert the measurements made from linear plunger type encoders along a contour to a graph of some sort. I want to be able to have a precision shaft with a linear encoder on it attatched to a plunger encoder (which will be in contact with the surface I want to measure), so I have essentially an x axis and a z axis. I don't need the y axis. Basically it is two encoders, one for x axis and one that measures the z-depth. I want to be able to drag this encoder over objects to get a profile from the side. So I will end up with a 2d graph. The plunger encoder is:
    http://www.usdigital.com/products/pe/
    Do you know of any easier ways to do this?
    Thanks.
    Mar 2004
    1661
    What you is looking for is a DRO (Digital Read Out) with recording functionality. I don't know if there's anyone cheap around, but it shouldn't a lot of work to do a DIY-version.
    Regards,
    Sven
  1. Digitizing Probe Question
    By Trainhound in forum Digitizing and Laser Digitizing
    Last Post: 01-06-2006, 12:25 AM
  2. digitizing probe
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 11-19-2005, 03:52 PM
  3. Bad Contour Error while Pocketing
    By sundara in forum BobCad-Cam
    Last Post: 05-29-2005, 12:10 PM
  4. Digitizing probe question for newby
    By Kitch02 in forum Digitizing and Laser Digitizing
    Last Post: 03-31-2005, 02:18 AM
  5. contour profile
    By stevieboy in forum Mastercam
    Last Post: 10-15-2003, 07:40 PM
