587,228 active members*
6,660 visitors online*
IndustryArena Forum > CAM Software > Mastercam > contour toolpath containment
    Feb 2009
    40
    Trying to cut a 2" straght edge of a part with a simple contour path in X3. Problem is the toolpath want to arc into cut and comes to far past the edge and will hit vise jaw. So I want to make a containment area or boundary, but can't seem to fin how to do this with a 2d contour? Is containment only a feature of 3d paths?
    Apr 2006
    3206
    Quote Originally Posted by fjbart70 View Post
    You can adjust the lead in/lead out angles and distances.
    Dec 2008
    717
    Yeah - try actually turning off the lead in/out to see if what that does for you. Then, if you want some lead in or out, turn it back on and start messing with the distances, radius', as well as on the bottom of the window - the extend/shorten.
    The default is like 100% tool diameter for distance to lead in and also radius, so it is pretty much ALWAYS too much.
    Tim
  1. Need help with Lathe Contour toolpath, please.
    By awolfoutwest in forum GibbsCAM
    Last Post: 11-23-2011, 05:23 AM
  2. Pocketing/ islands/ containment???
    By slideleft in forum Mastercam
    Last Post: 03-20-2009, 03:34 AM
  3. Incomplete toolpath on closed contour
    By LongRat in forum SheetCam
    Last Post: 07-11-2007, 08:51 AM
  4. Surface contour toolpath (odd)
    By jnc in forum Mastercam
    Last Post: 04-23-2007, 01:16 AM
  5. Chip containment
    By Cold Fusion in forum Bridgeport / Hardinge Mills
    Last Post: 10-12-2005, 03:25 PM
