588,156 active members*
5,111 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Contours or translate
Results 1 to 7 of 7
    Feb 2007
    505
    Cool Contours or translate
    If you look at the file , I would like to double the width of the double lines around this sign.If I use contour I never get exactly the same profile, if I use translate with scale how do I center it?
    Attached Files Attached Files
    Dec 2008
    4548
    Creatre a point at X= 7.3862 and Y= 4.3773
    Then translate/scale with the Scetch/Enter tab and use the Pick/Pick option. Select your line and press spacebar, then clcik on the point twice.
    Feb 2007
    505
    Quote Originally Posted by BurrMan View Post
    Were those coordinates obtained with center of gravity?
    Dec 2008
    4548
    Hi Claude,
    Entity summary with all objects selected...You can use the expression calcs of the field entry points to add the 2 values and divide by 2.
    Feb 2007
    505
    Red face unequal contour
    Not sure what I am doing wrong.
    I dont think you can scale an asymetrical form and end up with an equal offset all around...
    Dec 2010
    Quote Originally Posted by Claude Boudreau View Post
    Claude,
    you can try this.
    Dec 2008
    4548
    Yes like jepetara shows, you can offset the four sides seperatly and trim/extend 2 entities to connect the corners.
  1. Error at synchronisation of contours
    By qwerty1000 in forum Mastercam
    Last Post: 09-18-2009, 04:27 PM
  2. Contours vs. Profiles?
    By japcas in forum Dolphin CAD/CAM
    Last Post: 07-27-2009, 01:40 PM
  3. Remove contours of a shape
    By chips_ruiz in forum Visual Basic
    Last Post: 02-06-2008, 07:06 PM
  4. CAD/CAM for Instrument Contours?????
    By NardisAmps in forum Musical Instrument Design and Construction
    Last Post: 01-31-2007, 02:33 AM
