587,989 active members*
4,542 visitors online*
Results 1 to 6 of 6
    Jul 2005
    261
    Control panel faces
    I am retrofitting my Bridgeport CNC and want to remake my own control panels. I can handle cutting the shaping the aluminum to fit the buttons. So I'm looking for a custom printed face or something (that can stand up to oil and filth) I can put overtop of the bare blank metal.
    Does anyone know a cheap service or way I can do this? The machine isnt working yet so I can really use it for engraving or anything else.
    -Erich Stein
    WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
    Dec 2003
    24220
    What I do is use a local Lamacoid engraver, I send him a DXF or DWG file and he reverse engraves everything, this way there is no wear or ingress of dirt etc.
    You pick the main colour of the overlay, and the legends can be any colour you choose.
    See post #9 http://www.cnczone.com/forums/showth...light=acroloop
    I will find a better example with multi colour.
    Al.
    Albert E.
    Jul 2005
    261
    So reverse engrave - is RAISED printing / outlines?
    Dec 2003
    24220
    No, the front of the panel remains perfectly smooth, with no engraving, this is done on the reverse side, then the engraved portion is sprayed with the colour of choice and only this appears from the front.
    The reverse engraving goes through to the front translucent layer, this is then filled with the paint choice.
    Very effective and hard wearing.
    You do not get legends wear off like silk screening, or filled with grease etc.
    Al.
    Albert E.
    Jul 2005
    261
    Oh so very interesting thanks, and what an interesting idea.
    Dec 2003
    24220
    Another recent panel using this technique
    Albert E.
  1. Control Panel Cut out
    By scruffyjones48 in forum Employment Opportunity
    Last Post: 08-03-2008, 09:47 PM
  2. T32 Control Panel Lock up
    By bean79au in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-13-2008, 10:59 AM
  3. Versalaser Control Panel
    By Vice in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-22-2008, 10:15 PM
  4. My DIY control panel
    By DennisCNC in forum Community Club House
    Last Post: 10-03-2006, 04:24 AM
  5. Building my control panel
    By ChrisJ in forum CNC Machine Related Electronics
    Last Post: 03-03-2005, 03:09 AM
