587,193 active members*
2,575 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Control Panels - Getting Started
Results 1 to 4 of 4
    Aug 2008
    4
    I've been using our Heiz to cut Traffolyte control panels but have just bought a secondhand PNC-2300A to take over. I'm just wondering what the best workflow is?
    At the moment I've just got the standard Roland DR Engrave and 3D Engrave and we use Cut2D on the Heiz.
    I'm guessing the best workflow is something like...
    1) Engrave all the text with the depth regulator nose fitted and a 'V' tool.
    2) At the tool change remove the nose and swap to a parallel tool.
    3) Cut all 'through' holes.
    Any comments would be most welcome.
    The method you have described is exactly the way I would do it.
    Tweakie.
    CNC is only limited by our imagination.
    Aug 2008
    4
    Thanks Tweakie.
    Feb 2010
    17
    yep that works for me
  1. RFQ for aluminium panels
    By Surp in forum RFQ (Request for Quote)
    Last Post: 10-21-2012, 04:23 AM
  2. textured panels
    By cabnet636 in forum Camaster
    Last Post: 06-18-2011, 01:05 PM
  3. Help getting started (Control Circuit Specific)
    By Omnihiko in forum CNC Machine Related Electronics
    Last Post: 02-22-2011, 05:21 AM
  4. Looking for MN Machinist to make 2x control panels
    By Zero Cool in forum Employment Opportunity
    Last Post: 08-20-2010, 08:08 PM
  5. What's the finish they put on aluminum fire truck control panels?
    By SRT Mike in forum MetalWork Discussion
    Last Post: 12-30-2008, 05:48 AM
