603,407 active members*
2,218 visitors online*
Results 1 to 10 of 10
    Nov 2005
    111
    Controller Board for LinuxCNC
    Hello,
    does someone knows a controller board for LinuxCNC to control a lathe with step and direction servos what is connected to the PC with a usb or network cable?
    Hnas
    Jul 2003
    1766
    Re: Controller Board for LinuxCNC
    usb doesn't work with linuxcnc. Not realtime enough. There are a few ethernet solutions. The only one I am familiar with is mesa.
    The 7i92 is like 2 high speed printer ports right out of the box. You can buy daughter boards that expand the i/o and add functionality.
    the 7i76 is a ethernet+breakout board all in one.
    7I76E STEP/IO Step & dir plus I/O daughtercard
    gives you encoder interface / analog out for spindle + 48 i/o and 5 axis steppers outputs.
    Jan 2007
    599
    You could also look into ethercat, Linux cnc can use servo drives with ethercat.
    Mar 2004
    1661
    Step/Dir can be run with a parallel port and a breakout board. I have a few machines running every day with this setup and with a lathe you have one axis less so there should be enough of channels for you. If you want to run a tool changer it depends on your setup if a parallel port is enough, you can add a second port if you want to stay on the cheap.
    Sep 2010
    84
    The Mesa 7i76E is an ethernet card for steppers.
    JT
    Oct 2010
    1189
    jthorton is right but why do you need usb or ethernet ? my lathe and mills are verry happy without that - even the toolchangers. so where does that requirement come from ?
    Gesendet von iPad mit Tapatalk
    Nov 2005
    111
    I use UHUservo for the two axes, manually toolchange, two endswitches for every axe, two handwheels with A + B channel and a magnetic switch for spindle speed. For machining control I use a rugged Laptop with usb and network connector.
    Hans
    Oct 2010
    1189
    hi hans
    o h i see
    notebook ,..
    cu
    thomas
    Sep 2010
    84
    Quote Originally Posted by Holzwurm56 View Post
    Hans
    The power saving "features" in most laptops make them unsuitable for real time control.
    JT
    Feb 2008
    644
    Quote Originally Posted by jthornton View Post
    The power saving "features" in a laptop make them unsuitable for real time control.
    JT
    Though not ideal, some laptops _may_ be ok if you avoid certain operations
    I have used my Dell E6420 for testing our Ethernet cards and it works fine with LinuxCNC as long as you never
    change power modes (battery to line or line to battery) or adjust the display brightness/contrast with the function keys
    these both generate multi- millisecond latency spikes
  1. Replies: 70
    Last Post: 10-02-2023, 11:51 AM
  2. Which motor controller will work with LinuxCNC?
    By Merlysys in forum LinuxCNC (formerly EMC2)
    Last Post: 12-14-2015, 03:10 PM
  3. RT-8p8c - PIC32 based ethernet interface board for LinuxCNC
    By kinsa in forum PIC Programing / Design
    Last Post: 10-30-2015, 01:44 PM
  4. linuxcnc and xbox 360 controller?
    By MCRIPPPer in forum LinuxCNC (formerly EMC2)
    Last Post: 06-30-2015, 06:03 PM
  5. KL-4030 and C10 Breakout Board with KL23H286-20-8B motors and LinuxCNC
    By sbrendtro in forum Automation Technology Products
    Last Post: 04-04-2013, 03:35 PM
