603,371 active members*
3,993 visitors online*
Results 1 to 5 of 5
    Oct 2007
    7
    controller box
    Howdy
    OK lurker comin' out. Just a few shots of my controller. My ugly diy machine will follow soon. Keeling motors and 48 v. ps. Obviously G540, cooling fan from radio shack. Led's a surprise but what the hell. Do I need the fan? Thought the controller box was different and cheap!!!!!!!!!!
    Helllo all
    Jim L
    Attached Thumbnails Attached Thumbnails cntrl-oa.jpg   cntrl-oa1.jpg   cntrl-0a2.jpg   cntrl-int.jpg
    Dec 2005
    619
    Jim,
    Cooling fan is always a good idea, but it won't do you much good unless you have some way for the external air to enter the box and exit via the fan. I'm assuming you thought of that as well and have an air entrance cut out planned for somewhere on the case?
    Mark
    Oct 2007
    7
    Completed controller. I'm using stereo jacks and plugs for the limit switches. Does anyone think that could be a problem?
    Thanks Jim L
    Attached Thumbnails Attached Thumbnails DSC00274.jpg   DSC00275.jpg   DSC00279.jpg   DSC00281.jpg
    Sep 2009
    10
    What components did you use?
    Just curious on the size of your table and the components that you used. That our your motor sizes? I am gathering info to build my first cnc and the electronics are the barrier at the moment. Thanks
    Oct 2007
    7
    Exclamation
    howdy
    don't check posts that often. if your still there, i'm building a @ 20" x 20" x5" machine. 1/4-20 s-s-stl drive for now. want to learn. havin' trouble with the g540, only x y axis workin'. motors wired correct but only xy axis. gonna call macius.
  1. Controller
    By cjgaus in forum DIY CNC Router Table Machines
    Last Post: 10-02-2008, 09:15 AM
  2. DNC for 10M controller.
    By GPena in forum Fanuc
    Last Post: 12-15-2007, 06:11 PM
  3. PWM controller
    By sswitaj in forum CNC Machine Related Electronics
    Last Post: 08-27-2007, 12:28 AM
  4. DeskCNC 2nd. gen controller AND HobbyCNC Pro Controller
    By maycom in forum DeskCNC Controller Board
    Last Post: 06-02-2007, 07:33 PM
  5. controller
    By rickwinters in forum Gecko Drives
    Last Post: 12-15-2004, 12:46 AM
