I've searched but have not seen a comprehensive side-by-side comparison of controller hardware for driving Stepper motors. I'm still somewhat of a newbie so I may need more columns to get a useful comparison. Any info. or suggestions you could provide would be helpful. I'll update the table in this first post as new posts, suggestions, and input is added.
- - Legend - -Code:|Kit|U/B|Axis|Opto.|Type|_Steps|MBRD|$/Ch|Amps|Volts|_Tech_|_Controller_____| |###|###|####|#####|####|######|####|####|####|#####|######|################| |PCB|_U_|__1_|__.__|__._|___Y__|__._|$_22|__3_|_55__|18245T|_PicStep________| |PCB|_U_|__1_|__.__|__._|___.__|__._|____|__5_|_30__|IRLZ44|_PMinMO_________| |PCB|_B_|__1_|__.__|Chop|__400_|__._|__._|_2.5|_46__|L297/8|_PMinMO_________| |PCB|_U_|__3_|__.__|__._|___.__|__._|__._|__5_|_30__|_3977_|_PMinMO_________| |Kit|_U_|__4_|__N__|Chop|_3200_|__._|$_25|__3_|_42__|_7062_|_HobbyCNC_4AUPC_| |Kit|_U_|__1_|__N__|Lin.|_3600_|__N_|$_30|1.5_|_35__|TIP122|_Linistepper____| |Kit|_U_|_>3_|__N__|Lin.|_3600_|__N_|$_25|1.5_|_35__|TIP122|_Lini-InQty.____| |Kit|_U_|____|__N__|____|__200_|__N_|$___|3.0_|_35__|TIP122|_Lini-NoMicro___| |_N_|_U_|__1_|__N__|__._|__400_|__._|$__4|1.25|_35__|_5804_|_UCN5804________| |_._|_._|__._|__.__|__._|___.__|__._|$___|__._|__.__|_3977_|_3977/a3977_bd._| |_._|_B_|__3_|__.__|__._|_1600_|__._|$_52|_2.5|_35__|______|_Xylotex 3-Axis_| |_._|_B_|__4_|__.__|__._|_1600_|__._|$_46|_2.5|_35__|______|_Xylotex 4-Axis_| |_N_|_B_|__1_|__Y__|__._|_2000_|__Y_|$114|_7.0|_80__|Propri|_Gecko G201_____| |###|###|####|#####|####|######|####|####|####|#####|######|################| |Kit|U/B|Axis|Opto.|Type|_Steps|MBRD|$/Ch|Amps|Volts|_Tech_|_Controller_____|
Kit - KIT-Comes in a kit; PCB-PC boards available only.
U/B - Unipolar or Bipolar? (U/B)
Axis - # of Axis (or Channels)
Opto. - Does it have Opto-Isolation? (Y/N)
Type - Chp-Chopper, Lin=Linear
Steps - Steps per revolution, assuming a 1.8deg. motor.
$/Ch - Cost per Channel or Axis
MBRD - Mid-band resonance damping? (Y/N)
Amps - How many Amps will it support in the given mode? (Per Phase)
Volts - Max. volts supported.
Tech - The technology this driver is based on. (3977, TIP122, etc.)
- - PROS - -
PicStep - OPEN SOURCE
PMinMO - OPEN SOURCE
Gecko - Powerful?
HobbyCNC -
Xylotex -
UCN5804 - Really Cheap, easy to build
Linistepper - Less Expensive, versatile, OPEN SOURCE.
3977 -
- - CONS - -
PicStep - Soldering Required, No Kits available
PMinMO - Soldering Required
Gecko - Expensive
HobbyCNC - Soldering Required
Xylotex -
UCN5804 - Soldering Required, Really low power
Linistepper - Soldering Required
3977 -
Other related questions:
If a controller is NOT a Chopper or a Linear, then what is it?
[Edit: Added MBRD, Volts, Reformatted, Updated]
