603,935 active members*
2,996 visitors online*
    Sep 2008
    7
    Controller options
    Where is the thread for discussing various controller options?
    I have a small DIY router build in progress and I need a relatively inexpensive controller to drive three standard 1.8deg 1A steppers. I see this one on EBay and would like to ask some experienced people if this is what I need or not. I have a beefy 36V power supply. I have an ubuntu 8 machine running the latest EMC2 thru a parallel port.
    I suspect there is already a forum for this but I can not find it for anything.
    This forum is often used for discussing what motor controller to use with a router. There are also manufacturer specific forums on the main list as well as some general electronics forums.
    I've never heard of this controller before, but it seems like a good price if it works well and is big enough for what you need. If you want to use a 36V supply, this controller won't work - it only goes up to 24V according to the ebay ad. The typical ones used around here are Geckodrive's and Xylotex. The Geckodrive G540 would definitely be an upgrade (higher voltage, 4 motor drives, higher current, likely more advanced drive), but it's $300.
    http://geckodrive.com/product.aspx?c=3&i=14469
  1. looking for options
    By chunkymonkey in forum CNC Swiss Screw Machines
    Last Post: 07-16-2009, 04:21 PM
  2. Options with ordering a Keling Controller kit..
    By turbostang in forum Automation Technology Products
    Last Post: 08-29-2008, 05:56 PM
  3. To many options
    By dalescnc in forum CNC Machine Related Electronics
    Last Post: 08-04-2007, 03:12 PM
  4. P\S Options
    By Trentec in forum CNC Machine Related Electronics
    Last Post: 08-18-2006, 09:10 AM
  5. Help with CNC options please
    By djshop in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-05-2005, 05:45 PM
