I've come across a cold saw for a good price I would like to buy. How much trouble and expense would it take to convert it form 440 3ph to 220?
Thanks,
JStrayer
Thanks,
JStrayer
The simple way would be to use a VFD (variable frequency drive). If you spec the correct drive you can put any voltage in and get any voltage out. Just make certain the drive is large enough to provide the amps you need.
Albert E.
