603,946 active members*
3,506 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > convert 5v PWM signal into analog signal ranges from -10 to +10 v
    Aug 2014
    4
    hi folks
    I'm trying to do some custom servo motion control, for that purpose I need a basic circuit that converts the output signal from the controller that is 5v PWM and Direction digital output to analog signal ranges from -10v to +10v
    Example:
    PWM signal 90% and Dir 1 >> 9V output
    PWM signal 75% and Dir 0 >> -7.5v output
    I'll be very happy to see your suggestions
    Feb 2007
    972
    Re: convert 5v PWM signal into analog signal ranges from -10 to +10 v
    with my step 2 linear,. you could control the analog amp with simple step/dir signals
    Servo Adapters, ViperServo
    for the PWM signal, an opamp with lowpass filter, differential opamp with reference set to v/2 would do the job.
    Larry
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
    Jun 2010
    4260
    You can buy such units off the shelf.
    Cheers
    Roger
  1. Controlling motor with +/-10V analog signal
    By Sandy H. in forum DIY CNC Router Table Machines
    Last Post: 12-01-2013, 12:38 AM
  2. analog +/-10V signal gen
    By visky in forum Want To Buy...Need help!
    Last Post: 05-01-2008, 03:40 AM
  3. PWM and DIR -> +/-10VDC analog signal
    By visky in forum CNC Machine Related Electronics
    Last Post: 11-21-2007, 09:28 PM
  4. analog signal from serial port
    By roni21702 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-09-2007, 05:06 PM
  5. Getting analog signal from pc
    By roni21702 in forum Computers / Desktops / Networking
    Last Post: 06-15-2006, 07:34 PM
