587,986 active members*
5,011 visitors online*
Results 1 to 4 of 4
    Jan 2009
    33
    Convert the controller to inch
    I am working in a shop with a fanuc controller io-mb and its all metric. Can someone tell me how to change it so that its in the inch system.
    I am sure there is a way to change it within the program but that scares me because of mentaly jumping back and forth between the two measureing systems.
    I would like to know how to change the entire machine to think in the inch system.
    Is this as easy as "I" think it would be?
    Mar 2003
    2932
    In MDI, press OFFSET/SETTING function key. The first page (HANDY) has INPUT UNIT = 0 (0:MM 1:INCH). Change it to 1.
    You may also want to change parameter #3204 bit 0 (far right) to 1. This will display the Machine Position in Inches also.
    Jan 2009
    33
    Thanks a bunch
    Jan 2009
    117
    You can also command G20 in MDI or in your program and then Cycle start to set the control in modal condition for inch system.
    To change back to metric command G21 in MDI or your program
    The position screen will display 4 digits after the decimal point as soon as G20 is executed.
  1. Convert/Retrofit old Precix HPGL controller to G-code
    By Blluitt in forum Commercial CNC Wood Routers
    Last Post: 01-14-2012, 05:42 AM
  2. Steps per Inch / mm
    By themonster in forum Linear and Rotary Motion
    Last Post: 08-25-2008, 02:08 PM
  3. 6 inch jaws
    By DSL PWR in forum CNC Tooling
    Last Post: 11-13-2007, 03:24 AM
  4. I don't know if they got the mm to inch mixed up.....
    By spunky1974 in forum Uncategorised MetalWorking Machines
    Last Post: 11-23-2006, 04:04 PM
  5. turns per inch vs threads per inch
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 08-18-2004, 03:27 PM
