588,490 active members*
4,205 visitors online*
IndustryArena Forum > CAM Software > Mastercam > convert nurb spline to arc?
Results 1 to 18 of 18
    Dec 2011
    i have a solid model with an angled hole. i used create curve on one edge to extract the wireframe but it extracts a nurb spline instead of the curve i want. here is the file. had to change file extension to zip to up load. to open mastercam file change file extension to .mcx
    Attached Files Attached Files
    Dec 2008
    717
    Seems there is something wrong with your file...but have you tried "CONVERT NURBS" OR "SIMPLIFY"?
    Tim
    Dec 2011
    Quote Originally Posted by WallyL7 View Post
    i tried simplify. it did not covet the nurb spline to an arc. i did not try convert to nurbs because the end of the hole is already nurbs and i want it to be an arc.
    Dec 2008
    717
    Well, like I said, I can't open your file. You may just have to create your WCS in the view of the angled hole and draw a circle. Pretty simple and quick.
    Tim
    Dec 2011
    did you try to change the file extension and replace it with .mcx? i had to change the extension to upload the file. i just tried downloading the file and changing the extension and it opens with no problems
    Dec 2008
    717
    Ok - Not wanting to spend too much time on it I just didn't fiddle with trying to get it open. After changing the extension it did open.
    But now I really have no clue what you are trying to do. You have an arc on the flat/perpendicular side to the hole...and obviously a spline where it breaks through a non-perpindicular wall.
    I can't see what you are trying to do with this part. If you are drilling or milling it, then use the arc that is there.
    Like I said before, you will at least have to create a plane (tool plane/work plane) for that view anyway, and then you can use the arc that is already there. Whatever arc you create on the "spline" side won't help much IMO.
    Tim
    Dec 2008
    717
    Let me know exactly what you are trying to do and I can see if I can get you going in the right direction.
    Tim
    Jun 2010
    Quote Originally Posted by Joesph Jackman View Post
    I am not at my PC to try looking at your file; but have you tried using Verisurf's hole axis utility. It is a free add-in for Mastercam which may do just what you are trying.
    Here is a link to their site.
    Verisurf Software Downloads
    Apr 2003
    3578
    The Verisurf Hole axis tool is great for this. but for your part, I would go to the front arc and create a line from the end point and the mid point of the arc then I created line perpendicular to the line and was done.
    Remember a full circle in MC the polar angle of "0" is the end point and "180" is the Mid point.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Aug 2010
    101
    if you copy the spline to another layer (so you can keep the original), you can use the simplify tool to convert from nurbs to an arc. You might have to break that nurbs spline into multiple segments using the break two pieces tool and convert each segment into a separate arc.
    I haven't looked at your file, but I hope that helps.
    Dec 2011
    Quote Originally Posted by jamlab View Post
    i do not see any download for the verisurf hole axis utility when i follow your link. what does the verisurf hole axis utility do?
    Dec 2011
    Quote Originally Posted by mafitch7479 View Post
    i will try this. i did not try breaking the spline into multiple segments before. maybe that is why i had no luck. thanks.
    Dec 2011
    just want to see if i can convert a spline into a arc so i can pick up z values if in the future i need to do this.
    Dec 2011
    Quote Originally Posted by cadcam View Post
    good suggestion. thanks
    Jul 2009
    23
    Would also like to know what the Verisurf utility does!
    Apr 2003
    3578
    Cadcam
  17. #17
    Dec 2008
    3142
    This is the lazy way to get what you want.
    - create a surface from the wall of the hole ( in a different color, level )
    - untrim that surface
    - create a curve on the top and bottom of that cylinder
    ----- you now have 2 circles, at minimum and maximum extents of that hole. Easy to pick Top of stock of hole & the Depth when toolpathing
    - create line from top circle centre to bottom circle for the hole axis
    - you can use the circles to setup a plane for additional machining ( ie drill, interpolate, deburr etc )
    This is what the Verisuf utility gives you ( or very similar )
  18. #18
    Dec 2011
    Quote Originally Posted by Superman View Post
    thank you for taking the time to explain. what you wrote is "super" helpful to me. i am sure this technique will be very useful in the future as well.
    Again, thanks!!!
  1. software to convert spline curve to tangent arcs
    By foxfx in forum Uncategorised CAD Discussion
    Last Post: 05-08-2014, 02:31 PM
  2. convert spline into equal length segments
    By maxidex in forum Uncategorised CAM Discussion
    Last Post: 08-20-2010, 10:20 PM
  3. Take a look spline job
    By turboless in forum Employment Opportunity
    Last Post: 05-22-2009, 04:04 AM
  4. Haas VF3 Can it use nurb tool paths?
    By Rocko1 in forum Haas Mills
    Last Post: 01-29-2009, 04:16 PM
  5. arc and nurb filter
    By camtd in forum Surfcam
    Last Post: 07-25-2006, 01:48 PM
