603,310 active members*
2,330 visitors online*
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Nov 2013
    5404
    Re: Convert Step/Dir to +/- 10V
    to OP: forget trying to convert Step/Direction to analogue. As has been pointed out.....IF.....all you require is speed control, then a F/V converter will be fine. IF however, you require position control,
    then you need a PID feedback capable controller....and that is wasting your time. Buy a Step/Direction servo and be done with it. It will probably work out cheaper than any PID drive, but more importantly be
    way more certain at getting a good result.
    I use 750W Delta B2 servos, which are Step/Direction capable, and they are superb.
    https://www.fasttobuy.com/flange-80m...er_p28084.html
    Craig
  2. #22
    Jul 2007
    162
    For smaller machines agreed, but the machines I converted had massive servos and drives, that were fully functional and retaining the original equipment was a big cost and time advantage, as it was only the proprietary controller that was grossly outdated and becoming problematic. Using the audiohms converter solved that issue. I was able to update to a modern step and direction system, yet retain the original 'grunt'.
    Changing out the servos at this scale would have been expensive and mechanically challenging.
    If it was a smaller machine, sure junk it all and start over.
  3. #23
    May 2025
    I agree with rotec. As an illustration, see the example of a TOS CNC milling machine retrofit:
    http://www.audiohms.com/en/customers...6-tos-fkv50-en
Page 2 of 2 12
  1. Need To Convert DXF to SAT IGES or STEP file
    By Taleismin in forum Uncategorised CAM Discussion
    Last Post: 07-13-2014, 01:48 AM
  2. how do i convert 0.72°/step to 1°/step
    By Syphonics in forum Stepper Motors / Drives
    Last Post: 08-01-2009, 06:10 AM
  3. Replies: 17
    Last Post: 01-10-2009, 02:44 PM
  4. Convert +- Analog to Step & Direction ???
    By Argofanatic in forum Servo Motors / Drives
    Last Post: 01-20-2007, 10:47 PM
  5. Convert Step/direction to phase drive
    By jderou in forum Stepper Motors / Drives
    Last Post: 08-05-2005, 02:52 PM
