587,960 active members*
3,647 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Converting drawing for Burny CNC Plasma Cutter
Results 1 to 7 of 7
    Sep 2005
    41
    I am learning to use the Burny CNC Plasma Cutter at my school and not a single person has a manual for the unit. I have been able to load the canned shapes and cut out some pieces but I want to load some custom shapes into the cutter. The machine has a floppy drive which I assume is where I would load any drawings into the cnc controller but what format must they be in to get the machine to cut them? I have an AutoCAD drawing that I want to cut on the machine but don't know how to take the AutoCAD drawing and make it usable by the machine. Do I need to convert the drawing to G code? If so I guess I need to learn G code... hahaha
    I was able to cut this out and plan on using it for a compact hibachi grill...
    Thanks,
    Jeffrey Park
    Feb 2004
    361
    Did a quick search using dogpile, and found that the Burny3 uses standard gcode commands...
    an easy shape creator software I found was at http://www.enter.net/~schleinkofer/
    and it specifically shows the Burny3 plasma cutter, as well as it's supported G-codes..
    enjoy..
    Sep 2005
    41
    Thanks for the info. I've created a simple g-code for a turbo flange that I want to try and cut out Monday. I saved the G-Code as a .cnc and a .txt file but how do I now get it to the Burny? The unit has a floppy drive but will it read a .cnc file? I really wish I had a manual for this machine as I'd like to cut out some flanges so I can weld together a nice turbo manifold for my car.
    Thank you for all the help,
    Jeffrey Park
    Attached Files Attached Files
    Dec 2003
    24220
    Get your school to contact Burny for a manual, companies usually give prompt attention to places of learning (potential customers).
    There are three or four formats that the Burny can be set to, if it is a Burny three, if it is set to normal WADR it will read in a G code file if set that way, You will need to have a list of the M codes etc. which are in the manual.
    Al.
    Albert E.
    Feb 2004
    361
    On that web site address I mentioned before, he has a freeware part creation program. I dl' it, and set it for Burny...
    One of the file extensions it creates is .cnc
    Just throw it on the disk, and try it... in a 'test' mode first for safety, and to confirm the part...
    enjoy..
    Jan 2010
    7
    Is there any other software for the controller. I use Autocad to create drawings and convert them to DXF files which my burny software can read.
    Jul 2017
    Re: Converting drawing for Burny CNC Plasma Cutter
    Quote Originally Posted by porky118 View Post
    We use the Phantom II to control our flame table. You will need to "save as" from AutoCAD to " AutoCAD R12/LT2 DXF" format. Then use the load feature on the Burny setting "cad import" under options in order to use shapes drawn in AutoCAD. note: The shape must be a closed polygon.
  1. Plasma bevel cutting burny 10LCD+ code inside
    By MrElder in forum Waterjet General Topics
    Last Post: 12-09-2021, 12:46 PM
  2. Converting CNC fabric cutter to router
    By cmaas in forum Open Source CNC Machine Designs
    Last Post: 07-30-2014, 03:25 PM
  3. C & G Systems burny 5 with optical tracer plasma or oxy acet burn table HELP
    By carlmadley in forum Machinery Manuals / Brochures
    Last Post: 12-28-2013, 06:41 PM
  4. Replies: 0
    Last Post: 12-03-2010, 05:47 PM
  5. converting imported part drawing to mold drawing
    By msomerville in forum BobCad-Cam
    Last Post: 08-29-2008, 12:56 PM
