567,674 active members*
2,940 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Converting Illustrator files to Gcode files
Results 1 to 5 of 5
    Jun 2007
    4
    not sure if this is the right place for this if not moderators please move it.
    I am wondering if there is any way to convert Adobe Illustrator files to Gcode files for running on Hass CNC mills. If anyone has any experience doing this please let me know. Right now my files are saved just as illustrator files, if I need to save them as some thing different etc. please let me know.
    Thanks in advance:
    acoop101
    May 2008
    16
    Hi all,
    I am not familiar with Adobe Illustrator but if it can generate/export the file as an HPGL plotter file format (.plt extension), VEGA DATA-View will convert to plotter file to a 3D M and G code file. DATA-View turns the pen-up and pen-down calls into Z motion.
    This works for any application that can generate a 2D plotter file (Corel, Autocad, etc) and is an easy way to engrave/etch/cut graphics and text into your work.
    During loading you will be prompted for the depth of cut, retract distance, approach distance, and if you want to use G0 for rapids or a defined rapid feedrate.
    We are still working on development for 3D relief based on color/gray scale conversion. There is a fully functional demo posted on our web site: www.vegacnc.com on the downloads page. The demo will allow you to view/edit/animate/optimize 45 files before expiring.
    Any feedback would be appreciated.
    Enjoy!
    Nov 2007
    7
    Re: Converting Illustrator files to Gcode files
    10 years later... I had a similar problem and ended doing this tool to export G-code directly from Adobe Illustrator.
    I am sure other people is going to find it useful .
    enjoy
    https://diegomonzon.com/illustrator-to-gcode/
    Apr 2017
    9
    I save my illustrator files in the format .svg then you can open the file in the free software inkscape. You can use the gcode tools extension in inkscape to produce gcode.
    Nov 2007
    7
    A few more years later
    https://www.gcodetools.com
  1. Adobe Illustrator Files
    By jrmach in forum BobCad-Cam
    Last Post: 08-19-2013, 09:53 PM
  2. converting CT Scans [ dicom files] to cutting files
    By fiddlemakermike in forum General WoodWorking
    Last Post: 05-09-2013, 02:15 AM
  3. Need help importing dxf files from Illustrator CS4
    By rodjava in forum Dolphin CAD/CAM
    Last Post: 08-18-2010, 06:35 AM
  4. Need help converting dxf files to Gcode
    By Jackflash65 in forum Uncategorised CAM Discussion
    Last Post: 12-03-2008, 03:25 AM
  5. Adobe Illustrator Files
    By JOE65 in forum Autodesk
    Last Post: 02-09-2004, 11:20 PM
