Hello everyone. This post is for the Ulitmax 3/ Ulitmax 4 users wondering about the new WinMax Control. I went to tech school for two years where I learned basics of G&M code programming and have self taught myself on the Ulitmax 3 and 4 controls for 5 years making custom parts to production runs. My shop upgraded to the WinMax software on the Hurco HTX 500 4 months ago and this is my experience with the new software.
The Ulitmax 3 or 4 controls are pretty much the same thing being that they are both DOS base programming. The WinMax control is windows base and this is the biggest hurtle to get over between the two controls. When I first started using the WinMax, I was swearing at the thing. But the more I’m using it, the more I liking it. The biggest problem I had was navigating between the blocks while programming is quite a bit different and you need to make use of the full touch screen to be able to do it quickly. Also, saving and reading the programs in the “file tree” is different that the Ulitmax controls because it’s Windows base and not DOS. But once you get that figured out, it’s mostly down hill from there. Some of the new features with WinMax that I enjoy is you can add “blend moves” while milling left or right contours automatically using program parameters. You can turn this feature on or you as you like, however the default is set to on and I haven’t figured out how to change it to off cause that’s the way I like it most of the time. But when you need it, it sure is slick. The WinMax software also offers more tool descriptions in the tool set up page (I believe its 30), so now you can actually call your center drill and as a center drill and not a drill. You also have reamer, counter bore, counter sink, and engraver just to name a few. Another feature I enjoy is the change tool number function in the tool set up. Let’s say you want to move your .500” end mill from tool 6 to tool 16. Easy. Select change tool number, enter new tool number and all the tool info is transferred from tool 6 to tool 16. It also updates the program you have change to the new tool number, saving program editing time. I also like the new copy and past function in the program review page so you can copy and delete blocks quicker a easier than ever before witch comes in handy when editing the programs to reducing cycle time by reducing extra tool changes. One new option WinMax has that my boss is too cheap to buy is the Tool and Marital Database function. From what I read about it, It sounds like you can have a custom tool list and have separate speeds and feeds for different materials predefine kind of like you can with Gibbs CAM or Master CAM. I have not used it because we don’t have it, but I sure would like to give a try.
You also have new Solid Graphics to preview your program before running. But unless if you take the time to fill out the “stock material size” and “tool lengths geometry”, you will probably change the graphics settings back to wire frame like I did. But you can turn the “show run time tool” on and you can watch the tool cut the part while the program is running on the screen. I don’t know if it’s much use, but it sure is fun to watch.
One new surprised I found oust is the tapping cycle. We had the Ulitmax 4 control on the HTX 500 and the tap cycle wasn’t that great like all the Ulitmax control. Slow and inaccurate. They took a huge step forward addressing this problem when we upgraded to the new WinMax control. Now the spindle doses not orientate between each hole and the threads comes out better, you can acutely thread a thread gauge into the hold by hand! Even with a 6-32 at 600 RPM! Unlike the Ulitmax control where I had to slow it down to 300 RPM and sill had two chase threads by hand afterwards. And this was done only by upgrading the software on the machine, not the encoders, servomotors, or anything else like that. Weird.
According to Hurco, WinMax is now more compliable with “Fanuc” style coding that the Ulitmax in the NC mode but have not used the function yet so I can’t make any comments on this feature other that it supports more M codes in conversational programming (M99 and others).
There are some other things I prefer the Ulitmax control over the WinMax, but overall, the more I use it the more I like it. It biggest problem is getting over the learning curve from DOS base programming to Windows base. And if you want to transfer the WinMax program to the Ulitmax control, you have to “downgrade” the format type (.HWM to .HD3) which is a pain but not impossible. This is the single most reason why I do not like this software because Ulitmax 3 or 4 controls did not have this problem while transferring the programs. You can take the Ulitmax programs and upgrade it to WinMax control fairly seamlessly though.
There’s my 2 sense worth.
glovebox20
