588,099 active members*
5,375 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Coolant dripping behind Lathe turret??
    Oct 2022
    22
    I have an Okuma ES-L10 lathe and filled it with coolant for the first time. When the coolant pump is on, there is coolant dripping from behind the turret. Is this something I should be concerned about? Don't want something to get damaged or rusted.
    Matt
    Re: Coolant dripping behind Lathe turret??
    This is unusual, you might need to check if there is any leaking behind the turret.
  1. Replies: 7
    Last Post: 12-29-2023, 01:51 PM
  2. CNC Lathe turret coolant
    By Jones'r in forum Turning Machines
    Last Post: 04-07-2023, 03:30 PM
  3. Turret coolant lines
    By dannirr in forum Tormach Slant Lathe
    Last Post: 11-11-2017, 03:01 AM
  4. Clogged coolant between turret housing and turret
    By autotrol9 in forum Hyundai Kia
    Last Post: 07-10-2014, 10:40 AM
  5. Coolant seal...Cadet turret
    By Voss_Machine in forum Okuma
    Last Post: 11-02-2010, 09:23 PM
