I'm using a boring bar holder from Haas with a ER32 holder, this larger holder now blocks the coolant from reaching the tool. What do you guys do to get a flexible line adapted to the Haas boring bar holder?
We often use brake line tube for coolant nozzles that need to be bent around obstructions. It is possible to get fittings with a 1/8" or 1/4" male NPT one end and the female socket for the coolant line on the other; 3/16" diameter lines are the easiest to bend without kinking.
I did find a nice fittings and flexible copper tube for the standand tools but this block has (2) ball swivel type arrangements I've never seen before. I will take one into work today and see what a pipefitter can come up with something to fit this...
I was just out there having the best time... at home in a 2 car garage with a sweet machine.![]()
Haas supplies the parts you need to make the coolant go throught the er-32 collet chuck. You need to take out the small pipe plug in the back of the haas boring bar holder. Then attach the block off plate to the back. Last install the solid coolant nozzels. The coolant will flow through the er-32 collet chuck and through the collet onto your tool. You should have these parts if you bought your lathe new. Mine came with everything I needed.
