587,267 active members*
4,126 visitors online*
Results 1 to 5 of 5
    KyleH2 Guest
    Coolant through on a manual tailstock?
    Background: I have some Cleveland coolant through HSS drill bits and am holding them in a MT3 ER32 Collet chuck which has a coolant hole at the back. I am using this to drill a 21/32 hole in 1020 Steel and 304 SS on my 13x40 gear head MSC lathe and would really really like to use either air or coolant if possible. I have a coolant setup on the lathe but of course spraying it into the hole just makes a huge mess. If I could use the coolant holes already in my drills I think it'd really help me up productivity.
    My question: Can I some how get air or coolant into the tail stock so I can extend tool life?
    Thanks in advance. I am 20 years old and just starting out. I am also trying to get a Hurco KMB-1 3-axis CNC up and running both of my machines are in my garage.
    Jul 2005
    12177
    Is there enough space between the tailstock and the collet to tap a small pipe thread into the side the of the taper? Alternatively just drill a small hole and push in a small tube or make a small hose nipple to press in.
    KyleH2 Guest
    Hmm, good question. Right now I am using an MT2 taper in a MT3 sleeve because that's all the American seller had. When I get the MT3 ones from Hong Kong I'll check where it sits in the tail stock.
    Feb 2008
    8
    i would try to keep the adapter sleeve and turn it into a coolant adapter.
    you probably dont want to push coolant into the interior of the spindle
    if th ecollet chuck has a coolant hole in back you could plug it and add a side hole you can plumb coolant into
    KyleH2 Guest
    I'll keep that in mind but I am not drilling through holes so the coolant would go out flutes on to the pan and into the coolant return.
  1. I NEED: DX-32 manual, 1104-2832 VMC Operator's Manual, DX-32 CNC Control
    By vettespeed in forum Bridgeport / Hardinge Mills
    Last Post: 05-31-2012, 02:21 AM
  2. sl-30 tailstock
    By travis1 in forum Haas Lathes
    Last Post: 11-04-2008, 05:32 PM
  3. PROGRAMABLE TAILSTOCK
    By raulmees in forum Daewoo/Doosan
    Last Post: 07-25-2008, 01:30 PM
  4. Flood Coolant System for Manual Surface Grinders
    By widgitmaster in forum Uncategorised MetalWorking Machines
    Last Post: 08-19-2007, 07:38 AM
  5. TL-2 tailstock
    By rbest27 in forum Haas Mills
    Last Post: 11-11-2006, 12:20 AM
