587,636 active members*
3,731 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Cooling fans on l370mw
    Nov 2022
    22
    I just got an l370mw, and the cooling fans always run on the hydraulic units, even when it’s in power save mode. My mcv4020 shuts everything off when in power save mode. Is there some parameter that changes this? I’m not a mass production shop so my machines see a good bit of idle in between runs.
    Jan 2013
    474
    Quote Originally Posted by Cris_co View Post
    Perhaps you have a faulty relay or contactor, ie stuck on?
    Alternatively, it would be easy for an electrician to wire in a relay for the fan to drop out in power save mode, or drives off.
  1. Cooling Fans for Control Electronics
    By mpowley66 in forum CNC Machine Related Electronics
    Last Post: 11-30-2016, 08:31 PM
  2. Mazak cooling fans
    By Fabdawg in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-02-2015, 11:41 AM
  3. Cooling Fans...AC or DC?
    By BlastedBilly in forum CNC Machine Related Electronics
    Last Post: 08-05-2014, 04:22 AM
  4. Replacing rear cooling fans on older Haas VF-0
    By lkenney in forum Haas Mills
    Last Post: 12-20-2008, 05:39 AM
  5. CNC machined cooling fans
    By mroy0404 in forum Hobby Discussion
    Last Post: 05-20-2007, 03:06 AM
