In auto can you can use a array command to copy a object and array it around a axis. How can I do that in XR? It's similar to the hole command in XR.
Paul in this example you just:
1) Select Object to array
2) Edit>Rotate>
3) Enter number of copies (this example = 6)
4) Seect "Rotate around a line
5) Select angle to rotate, in this case it would be 360/6 = 60 degrees
5) Click OK
6) Select the line/axis to copy around
AH, I see OK thanks I will give that a try.
Paul,
Using the same funcition you can alos choose to rotate around a variety of locations, point, coordinate etc.
OneCNC-USA
Simple enough, I missed that one, thanks.
