603,958 active members*
2,024 visitors online*
    Mar 2019
    Copying FIles getting Changed
    I am having some trouble copying files from HDD or Floppy to T4 Parts Program Directory.
    When I do smaller files say 20Kb or less I don't seem to have any problems. I am currently trying to import a 135Kb file and it does something during the "editing" part of the process that changes it to 29Kb and the Gcode is all garbled.
    The only thing I can surmize here might be that I have to many lines of code from the CAM?
    Help?
    Mar 2019
    Re: Copying FIles getting Changed
    Turns out N9999 is the max on the Dynapath controller we have. Resolved.
    Aug 2009
    1573
    Quote Originally Posted by ejg3855 View Post
    ...yes, Setup your post processor to start renumbering after N9999 Max then N0001 again. Also, you can insert/add blocks if and when editing using a decimal point. Nxxxx.xxx format of 4 place before and 3 place after decimal point.
