603,844 active members*
4,077 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Coreldraw - can't delete a path for my plasma file
Results 1 to 5 of 5
    Sep 2005
    287
    Hi All,
    Using Coreldraw and I'm trying to figure out how to draw a number of shapes along a path then I want to be able to convert those shapes to a dxf file for my plasma cutter. Sounds simple enough and I have managed it apart from one problem.
    I found out about the interactive blend tool (or blend tool). I draw a wavy line (the path) for example and have a row of circles running on that path. My problem is how can I get rid of the path itself, and leave just the circles. I can turn off the outline on the path and the path dissapears off the screen but that doesn't actually remove the path itself, it still comes out in the dxf file.
    There's also a command to remove the objects from the path but doing so just ends up with all the circles in a straight line.
    Anybody know of any alternative technique to accomplish drawing objects along a path and then get rid of the path. Even copying the objects without copying the path but I can't seem to do this.
    Thanks,
    Keith.
    Oct 2008
    406
    Go to Arrange and select Break Blend Group Apart. Then you should be able to select your original curve and delete it.
    Bob
    "Bad decisions make good stories."
    Sep 2005
    287
    Bob
    I must be doing something wrong. You are the second person who has told me to do this but all I have on my "arrange" menu is "break apart" (ctrl-K), not "break blend apart" and it's greyed out.
    Keith
    Sep 2005
    287
    Bob
    I got it working. I don't know what the problem was before but after seeing your post I went and tried again and there were the wonderful words "break blend apart" this time.
    Exported as a dxf file to my cam program and got the cut paths.
    Thanks very much,
    Keith
    Oct 2008
    406
    I've noticed with Draw it depends on what you have selected. Sometimes you just have to experiment to get the right thing selected. Glad you got it worked out.
    Bob
  1. MasterCAM .nc file path location help
    By ljagger in forum Post Processors for MC
    Last Post: 10-18-2010, 03:51 PM
  2. tool path from stl file?
    By Tristar500 in forum 3D Printing / Scanning Software and Hardware
    Last Post: 07-23-2009, 02:18 AM
  3. Replies: 1
    Last Post: 05-05-2009, 08:11 PM
  4. Command file to delete files
    By Karl_T in forum CamSoft Products
    Last Post: 09-07-2008, 12:05 AM
  5. Optimized tool path plasma/laser/punch
    By Independent CNC in forum News Announcements
    Last Post: 03-01-2007, 09:41 PM
