I am planing to build a DIY CNC laser cutting machine to cut a 7mm corian using a 120W CO2 chinese laser tube.
Any body try this before? and for laser experts is this possible?
Thanks,
Abdullah
Thanks,
Abdullah
S A Abdullah,
yes you can cut 7mm corian using 120 or even less
Good Luck
yes, that is right!
All chinese lasers over 100W are not stable in output power. We have here a 80W laser and sometimes the power fluctuating some times. Dont buy a laser over 100W!
best regards
Michael
What are you cutting out? What edge cut quality do you need?
If your cutting any thin sections clean through, the Corian can warp.
I make harmonicas from Corian and some colors are unusable.
I know that sounds weird but darker colors get allot hotter than light colors.
I cut it at 4 inches per min using a 2hp Hitachi router, 2 flute endmill.
I am also using an Exair cold air gun. It helps allot but some colors still warp.
I tried running some through a planer ( scary) and it warped the h@ll out of it.
Beautiful finish though.
hello
I am planing to build a DIY CNC laser cutting machine to cut a 20mm wood
what type of laser tube ?
what laser power in watts?
price in us $?
thanks,
maher
