603,882 active members*
5,282 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Correct Stepper Wire ? ?
    Sep 2003
    1490
    I went to a electronic supplier and asked for 4 conductor 22 ga shielded wire.
    They sold me some and when I got home and was cutting it I discovered it was two bundels of two wires each, and each pair being twisted. Each bundle of two wires was wrapped with foil and had a bare stranded wire between the foil and the two in sulated wires.
    Is this wire OK to use on my Xylotes stepper system?
    I'm a newbie and kinda concerned since the wire that came from Xylotex was a bundle of four wires and then a wire mesh around all four and the wire I baught was configured differently.
    Dec 2003
    24260
    This is know as individually shielded pair cable, it offers a little better shielding than overall shielded pairs, ground one end of all the bare drain wires, to avoid ground loops it is best to set up a common ground point for all power supply commons (if you have grounded supplies) and all shields etc.
    Al
    Albert E.
  1. 8 wire Stepper motor wiring connection
    By hornet in forum Stepper Motors / Drives
    Last Post: 01-25-2013, 07:52 AM
  2. Using Cat 5 cable for stepper motors?
    By 10bulls in forum CNC Machine Related Electronics
    Last Post: 04-24-2005, 04:24 AM
  3. 12 wire stepper
    By extreme in forum Stepper Motors / Drives
    Last Post: 03-25-2005, 12:56 AM
  4. How to Wire the Camtronics Stepper motors?
    By Cold Fusion in forum CNC Machine Related Electronics
    Last Post: 05-27-2004, 08:15 PM
  5. 10 wire stepper
    By xairflyer in forum DIY CNC Router Table Machines
    Last Post: 01-08-2004, 09:19 PM
